@Snake Plissken - It's always a hotly debated topic anyway and all have recommendations and complaints for each brand/version/viscosity. Which version of the Amsoil are you using (Signature Series, Extended Life, OE, European)? Is it the same version and viscosity in each of the fleet? What is the cost of the oil for each of them for the 10k/1yr? Which filters are you using with them? Which lab for the UOA's?
I just sent samples not long ago from my Pilot to Blackstone and Oil Analyzers. Most wear metals were close but the fuel dilution #'s from Blackstone were much lower. Many on line say not use them if you want accurate FD #'s.
I always have my own internal dilema's and eye twitches thinking when to do it next with which oil and filter. For my short trippers, I'd rather get a good off the shelf oil from WM in a higher grade and change earlier to get the fuel out. My Accord I could probably do longer than I am but I haven't sent any samples in. As it gets to about 5k, currently it's using about 1.5-2qts along the way. That's with new PCV, cleaning oils, flushes etc. Pretty consistent and partially due to my driving style.
Some of the other boutique oils may last even longer for you and possibly be less expensive in a $/mile ratio. With the different Euro ratings some of the OTS Euro versions may also perform for at least that because they had to get the certifications. Only way to know of course is to test each one in your vehicle and that's gets expensive quickly. I know for me, getting good oil on sale with filter is less than a test to say I can go longer. I think Blackstone is $40 now for a test. I got Mobil 1 Hybrid 0W-20 on sale for less than $2/qt. It says it's good for 15k miles "guaranteed". So for me changing at 7500 miles to be "safe" if I wanted is only $15 including a Premium Guard EX filter.
I don't know the member discounts but Amsoil SS on website shows $15.49/qt so about $75 with filter for my Accord to get 10k/1 year. Amsoil says up to 25k OR 1 year.
