2006 Accord Coupe 4 cylinder K24
I've been looking into air intakes and how they perform, stock vs. cold air vs. short ram. I was originally thinking that if I were to get an air intake, I would likely go with the short ram, although upon further research I keep reading that it actually loses power in the low rpm range, which is where I am most of the time considering it is my daily driver. I've also read that larger diameter intake pipes means less intake velocity, which in this regard is not as ideal as the stock setup, even if improvement can be noticed in the higher rpms. Apparently it is ideal at a certain pressure threshold or something, though my lack of knowledge in this area is why I am here.
I was hoping someone could shed some light on this - I won't be putting a turbo in it, I won't be using it to race, it's my daily driver. I just love driving it, as it is my first stick shift, and it is quite fun, and so I do intend to eventually find a reputable tuner for the engine. With these things considered, If anybody knows whether or not an aftermarket air intake is actually worth it or not for a daily driver, please feel free to let me know and hit me with the technical talk.
Thank you!
Thank you!
