https://automobiles.honda.com/accord-sedan#specifications
Can someone help me interpret this? The fuel economy attachment at the bottom is off Honda’s website (above) for the 2018 Accord. I’m not quite sure how to read it.
As a start, we know the CVT is offered only with the 1.5T. Therefore we know the 1.5T-CVT Sport is rated at 29 city, 35 highway, 31 combined.
However the 6MT does not seem to specify which engine it describes (or does it?). It appears to describe the 1.5T-6MT. Surprisingly it seems the 1.5T-6MT and CVT have the same highway fuel economy – 35 mpg. Isn’t that odd given the 1.5T-6MT is geared higher, ≈2,300 rpm at 60 mph versus ≈1,800 rpm at 60 mph for the CVT? (This is for the same 19” wheels. The 17” wheels get 38 mpg highway.)
If you look further, there appears to be no clearly stated fuel economy rating for the 2.0T-6MT. (Could Honda have mistakenly omitted it?) The 10AT-2.0T is rated at 32 mpg highway (19” wheels) and 34 mpg highway (17” wheels). If no specific fuel mileage rating is stated for the 2.0T-6MT, should we assume it is the same as the 10AT? I find that very hard to believe given the 10AT cranks about 1,500 rpm at 60 mph verses about 2,150 rpm at 60 mph for the 2.0T-6MT. You’d think the 10AT would get better highway fuel economy, and maybe it does. But given that the 1.5T-6MT and CVT are the same, it makes me wonder.
I am curious to learn more about turbochargers. With NA engines, lower rpm implies wider throttle opening and lower pumping losses (on the intake side). That is what boosts efficiency and fuel economy. However, if turbos maintain low boost on the highway and that low boost eliminates intake vacuum and therefore pumping losses on the intake side, does that negate the benefit of lower rpm for better highway fuel economy?
If the MT Accords do in fact get the same highway fuel economy as their CVT or 10AT counterparts, that’s great. The last-gen MT fuel economy penalty may no longer apply. Wouldn’t that be nice?
