I have a 1.5 liter sport and used Kroger’s Additech today because I had a ton of points. Was this a bad idea? Anyone use this stuff? What was your experience?
I find it interesting that ARCO is listed as a Top Tier gas brand. That would be a last resort type of choice for me - Shell, Chevron, Mobil, and 76 are pretty much my go tos around here in So Cal. I tried Costco for the first time last Thursday, just to try it - so far so good.The manual and general recommendation is to use Top Tier gas - Kroger isn’t on the list: https://toptiergas.com/licensed-brands/
Why is Kroger gasoline suspect? I prefer top tier gas but your car will run just fine on Kroger.have a 1.5 liter sport and used Kroger’s Additech today because I had a ton of points. Was this a bad idea?
Highly unlikely. It might be worth it on a turbo engine.I use kroger almost everytime I fill up my accord. Is premium (91 where I am unfortunately) worth it on a 17 year old car?
It is true. Do you think each gasoline brand has their own refinery that converts oil into gas? Of course not as they're very expensive to operate. Trucks get their gas at a filling terminal and then they dump in the detergent additives specific for each brand before delivery.This could be BS, but I have read that multiple stations in the same vicinity can get the same gas deliveries regardless of brand. Say if a small rural town has three gas stations--i.e. Shell, Irving, and Exxon--all three get gas from the same delivery truck. Might not be true, but it makes sense.
Not always the case as I showed with BP in my post directly above yours.Top tier brands use more detergents
GM mechanic by day,... a chemical engineer for a fuel company by night?We had a GM mechanic in our family and he said to always use top tier name brand gasoline and to always use the same pump at the same gas station whenever possible
If your tuned or use Arco constantly yes you may see some benefit. Not stock. The ECU is set to adapt to the factory recommend fuel, meaning it won't adjust timing, boost ect higher to compensate for better fuel. Now of you got a bad batch it will pull timing ect to save engine from detonation.Is there any benefit to using 93 octane in the 2.0T or is it a complete waste of money?
What's scarier is all these trading houses who are now sitting on hundreds of millions of barrels of oil they bought when it went to zero. But I digress...... Arco is the only brand I stay away from btw.I want to add that oil is a commodity. Yes, you are burning oil from Iranian soil, or Venezuelan soil, or from the Great state of Texas, etc....
Thanks. Problem solved. I don’t trust the gas at the Kroger stations so I‘ll use Shell. It’s common knowledge their gas is high quality. I went on gas buddy and found a Shell 1.2 miles away from me thats price was the same as the quick trip I’m used to using and found out that they do accept Kroger rewards. I wish I would have been known about this earlier. I’m like you, I’d rather use top tier.Unless this isn't the case where you live.....
Kroger/King Sooper fuel points can be used at Shell stations as well, and Shell is on the top tier list.
I stick to the list because the owner's manual says to. Not worth the couple cents fuss.
Lol you obviously didn't read a single word I wrote. ALL FUEL IS TOP TIER. If Kroger and Shell have a partnership like that it's more than likely because they use Shell gasoline in their tanks but didn't want to pay the licensing fees to Shell or pay them a portion of their sales, instead passing those savings to their customers. She'll charges someone six figures to use their licensing and canopy wraps ect, plus they take a portion of your gallons sold. Tbh I could easily find out with one phone call what their partnership is but after years of experience I have a basic idea already.Thanks. Problem solved. I don’t trust the gas at the Kroger stations so I‘ll use Shell. It’s common knowledge their gas is high quality. I went on gas buddy and found a Shell 1.2 miles away from me thats price was the same as the quick trip I’m used to using and found out that they do accept Kroger rewards. I wish I would have been known about this earlier. I’m like you, I’d rather use top tier.
Yes.Is it fine though?
