and if it's too low, the maintenance minder will notify you.
Please help me out here.(no enginer in my familly)Are you saying the "Maintenance minder"has an oil level sensor in the engine?
No, I actually made a mistake by grouping the maintenance minder in with the oil pressure indicator. By measuring oil pressure, the computer is essentially measuring oil levels, along with a possibility of faults in the system. Oil pressure sensors don't have a habit of breaking easily, so if your oil light is on, it's probably due to low oil pressure=low oil levels. I haven't read anything on this regarding the new Accord, but some cars have an oil pan level sensor that gets triggered if the level is too low. As far as I know, though, the new Accord i4 only has an oil dipstick as a visual oil level sensor. I made a mistake called the oil light the "maintenance minder." They're obviously two different things. If your oil level is low, the low oil pressure indicator will light up.
If your engine is that low on oil, it's for a reason, and chances are, it's going to be dirty as dirt!!
I agree to disagree,different engines burn more or less oil(specially when newish).I dont see how would you contaminate the oil in your engine by adding a fresh 1 qt.of oil
Of course there are exceptions. My Passat was an oil hog. I had the oil tested a few times, because I wasn't sure if I wanted to buy it out after the lease do to it "burning oil." The tests required fresh oil, along with running oil samples. I was using Castrol full synthetic approved for VW. Though the oil looked visually clean on test paper, the test showed higher than average build up of carbon, and lower than adequate levels of zinc. Low quantities of zinc mean the oil is now insufficiently doing it's job at preventing wear, or reducing friction of metal to metal parts. If you were to "top off" oil in this case, you would be reducing the amount of zinc available to adequately create a buffer between metal to metal contact, because it now gets diluted in with the old oil. It's not good, and you're only prolonging your driving abilities for a short bit.
Cheers:salue:
It was probably assumed since you said
Hi :naughty:, nice to meet you to:wave:
That's the problem with assumptions.
The above statement is also a bunch of hogwash. A visual inspection of oil will not tell you whether the oil is good or bad and needs changing.
Not at all. You are prolonging the oil life because you are diluting new oil into old oil, which means you will get longer oil life, but have that used oil in your car for longer times. The MM doesn't even matter because it doesn't measure the actual quality of the oil. Most oils are created with oil content that naturally darkens with wear. That's not to say a dark oil is bad, or is providing insufficient cooling or lubrication, though. The cleanest oil color is always the color that it was when you put it in. Any color shift after that is due to wear, and chemical reaction, or the contamination of leftover oil. Patterns of oil wear are noticed if you make it a habit of visually checking your oil, which the manual suggests you do. The more the oil wears, the darker they get. There are exceptions to this, such as heavy machinery that uses thicker, darker oil, but obviously, for cars, the saying has been consistent since cars got their first oil dipsticks: if it was clean when it went in, and dirty when it came out, your oil is dirtier than when it went in. You have to really want to argue to argue against that.
You can tell a lot from visually looking at the oil, such as if it's been contaminated with coolant, excess carbon buildup, filter problems, and a whole sort of problems. There's also many types of test paper that tells a lot more than your eye can see. Apart from oil wear, if a car is burning oil , and you notice that the color is similar to what it was when you replaced it, it is usually a sign that there's a bad gasket somewhere.
Curious though. How does topping off your oil "prolong oil life" and cause one to use "contaminated oil in your engine for longer times?"
from my previous comment you quoted me from=
If your oil level is down, don't top it off. This causes a prolonged oil life, which means you will be using contaminated oil in your engine for longer times.
I guess you must have a seriously narrow mind of thinking.
Not it doesn't. The maintenance minder shouldn't only let you know when certain maintenance is due.
If you read my last comment, I somehow bunched up the oil pressure indicator and maintenance minder into one without thinking about it. Oh will you ever find it in you to forgive me???
Hope this "engineer" didn't tell you all this.
That's a great comment, coming from someone who sure as hell didn't provide a lot of insight into anything.
I'd be more than welcome to talk over pm with you, because I don't want to hog this up.
