1 - 20 of 90 Posts
aeoporta
· moooo
After seeming to have to answer the same questions I figured I would start a little quick faq for everyone. It is in no way complete and will have to be updated in the usual manner.
Thanks
Brakes
Rear Brakes or put on some good ceramics with new rotors
Brakes eat themselves prematurely
http://www.driveaccord.net/forums/showthread.php?t=39985
http://www.driveaccord.net/forums/showthread.php?t=40784
http://www.driveaccord.net/forums/showthread.php?t=40775
Brake Pad Thickness
http://www.driveaccord.net/forums/showthread.php?t=38726
Front Brakes or put on some good ceramics with new rotors
Front Brakes eat themselves prematurely and causes juddering
http://www.driveaccord.net/forums/showthread.php?t=40393
Honda Settles Class-Action Suit Over Brakes
http://wheels.blogs.nytimes.com/2010/04/06/honda-settles-class-action-suit-over-brakes/
Exterior
Rock Strikes/Road Debris will damage A/C condensor:
Get Odyssey Grille or lower bumper billet
http://www.driveaccord.net/forums/showthread.php?t=33014
http://www.driveaccord.net/forums/showthread.php?t=37979
http://www.driveaccord.net/forums/showthread.php?t=35422
http://www.driveaccord.net/forums/showthread.php?t=27748
Windshield chips and is prone to being cracked by road debris
Advice: avoid semis
Paints chip/crack/peeling easily due to environmentally friend water based paint.
Possible fix: take back to dealership for repainting
Protect paint with clear bra, wax car to aleviate issues
http://www.driveaccord.net/forums/showthread.php?t=34058
uneven exhaust for all those with dual exhausts
http://www.driveaccord.net/forums/showthread.php?t=41119
Engine/Under the Hood
Cold Weather Performance
the starts
http://www.driveaccord.net/forums/showthread.php?t=40197
http://www.driveaccord.net/forums/showthread.php?t=40588
http://www.driveaccord.net/forums/showthread.php?t=40714
http://www.driveaccord.net/forums/showthread.php?t=41182
the grind
http://www.driveaccord.net/forums/showthread.php?t=40483
http://www.driveaccord.net/forums/showthread.php?t=40124
ah she be a tempermental lad
http://www.driveaccord.net/forums/showthread.php?t=40152
engine rattle on cold start
http://www.driveaccord.net/forums/showthread.php?t=40651
TSB: http://www.driveaccord.net/forums/showthread.php?t=30048
Battery dies early/Light flickering. Replace oem battery with one that has higher cca and that is better.
4cyl light flickers A bigger battery will reduce the flickering aka you will notice it less.
6cyl flickers to an extent. HID kits install do not have this issue
http://www.driveaccord.net/forums/showthread.php?t=39414
http://www.driveaccord.net/forums/showthread.php?t=39345
http://www.driveaccord.net/forums/showthread.php?t=39031
CAI/SRI and V6 accord issues
http://www.driveaccord.net/forums/showthread.php?t=41159
Heater/hvac, side mirros, seat heaters, high beams stops working
electrical short replace fuse 16
http://www.driveaccord.net/forums/showthread.php?t=40269
http://www.driveaccord.net/forums/showthread.php?t=41258
Oil consumption: Aluminum engines burn oil, vtec burns oil,pcv,
bad break in, leaks, etc
http://www.driveaccord.net/forums/showthread.php?t=39440
http://www.driveaccord.net/forums/showthread.php?t=40618
http://www.driveaccord.net/forums/showthread.php?t=40320
http://www.driveaccord.net/forums/showthread.php?t=41507
http://www.driveaccord.net/forums/showthread.php?t=28998
Manual Transmission 3rd Gear pop: related to tsb: Synthetic/semi synthetic
transmission fluid aleviates this issue. Consult 7th gen 3 gear pop solutions.
http://www.driveaccord.net/forums/showthread.php?t=41881
Interior
Seats: squeak, need readjustment
http://www.driveaccord.net/forums/showthread.php?t=39240&highlight=power+seat
http://www.driveaccord.net/forums/showthread.php?t=40605
Audio
EX and up: disable anc mics in front and rear or your sub will blow
FYI: Get a battery that can support your audio dreams
Dash kits: metra kit and scosche kit
6.5" speakers all around, custom enclosure for sub
http://www.driveaccord.net/forums/showthread.php?t=19635
http://www.driveaccord.net/forums/showthread.php?t=19987
http://www.driveaccord.net/forums/showthread.php?t=15874
How to disable A/C in Defrost mode (All Models except EX-L/EX-L V6)
http://www.driveaccord.net/forums/showthread.php?t=40680
Test your 8G electronics.
http://www.driveaccord.net/forums/showthread.php?t=44398
those with AUTO Window issue
http://www.driveaccord.net/forums/showthread.php?t=45461
Clutch clicking, squeaking, or creaking
http://www.driveaccord.net/forums/showthread.php?t=40671
TSB (some TSB are listed in other sections for better reference)
08-09 rear shelf rattle on rough roads 08-083
http://www.driveaccord.net/forums/showthread.php?t=32389
CD player/changer not working or broken
http://www.driveaccord.net/forums/showthread.php?t=28359
08 L4 glove box rattle 08-037
http://www.driveaccord.net/forums/showthread.php?t=21558
08-09 L4 blower motor noise 09-093
http://www.driveaccord.net/forums/showthread.php?t=40508
TSB for 3rd Gear Grinds, Pop Outs, etc.
http://www.driveaccord.net/forums/showthread.php?t=17047
08-09 engine whine 09-084
http://www.driveaccord.net/forums/showthread.php?t=40510
Power steering pump whine,
http://www.driveaccord.net/forums/showthread.php?t=39231
08-09 steering wheel pop 09-078
http://www.driveaccord.net/forums/showthread.php?t=40703
Key Fob not working: clean key, rotate battery 90degrees, there is a tsb on this
http://www.driveaccord.net/forums/showthread.php?t=27967
http://www.driveaccord.net/forums/showthread.php?t=42186
Faded keys
http://www.driveaccord.net/forums/showthread.php?t=40530
TSB & etc: Go Go gadget princess :)
http://www.driveaccord.net/forums/forumdisplay.php?f=28
Modifications
M3 roof spoiler
Where did you get your roof spoiler? (courtesy of StarBai)
http://spoilerandwingking.com
Call them (They do not have it listed on the site) and tell them you want it in 46.1" (46 1/4") size (for the coupe)
and paint code, I measured the area already. It was about $67 including shipping.
For sedan 45.25" maybe, Just to be safe measure it yourself to be certain
http://www.driveaccord.net/forums/showthread.php?t=41418
JDM Inspire decklid replica
http://www.driveaccord.net/forums/showthread.php?t=38740
Wheels
Wheel offset chart
http://www.driveaccord.net/forums/showthread.php?t=15096
TripleTred and Tire Size/Rim Size Calculator
http://www.driveaccord.net/forums/showthread.php?t=22114
Offset calculator
http://www.driveaccord.net/forums/showthread.php?t=27346
oem wheels for cheap
http://www.finishlinewheels.com/HONDA/ACCORD/2008/
TPMS reset sensors tool: ateq quickset
http://www.driveaccord.net/forums/showthread.php?t=29781
TPMS and Tint/iPhone: tint metal sometimes triggers tpms light (maybe)
http://www.driveaccord.net/forums/showthread.php?t=38751
Chasis tightening
Sedan: Ex and up comes with front strut bar aka Front Shock Tower Bar
Coupe: Front Shock Tower Bar standard on all trims
http://www.driveaccord.net/forums/showthread.php?t=39127
Want them: sponsors corner
COILOVER and SPRING FAQ
http://www.driveaccord.net/forums/showthread.php?t=41541
TSX Rear Sway Bar best 70 bucks you ever spent
http://www.driveaccord.net/forums/showthread.php?t=37872
http://www.driveaccord.net/forums/showthread.php?t=35989
HID
08+ Accord Coupes: H11 low beam, H11 fog lights
08+ Accord Sedans: 9006 low beam, H11 fog lights
Installation Example:
http://www.driveaccord.net/forums/showthread.php?t=22469
Where to get your hid kits etc, hit up sponsors corner lots of info, failure rates, etc.
Hid noobs read first!!!
http://www.driveaccord.net/forums/showthread.php?t=44506
Headlight Retrofit
Sedans require retrofit with hid projectors to eliminate glare. Coupes come with xenon
projectors already.
DIY or send to a lighting place example: lightwerkz.net
aftermarket retros
http://www.driveaccord.net/forums/showthread.php?t=41109
Parts
www.handa-accessories.com
www.bernardiparts.com
www.collegehillshonda.com
Extended Warranty Sites
http://www.saccuccihondacare.com/
http://www.bernardiservicecontracts.com/
http://www.curryhondacare.com/
2008 Honda Accord Instructions
http://www.driveaccord.net/forums/forumdisplay.php?f=52
2009 Honda Accord Instructions
http://www.driveaccord.net/forums/forumdisplay.php?f=57
2010 Honda Accord Instructions
http://www.driveaccord.net/forums/forumdisplay.php?f=58
Honda Service News
http://www.driveaccord.net/forums/showthread.php?t=8253
7th gen Faq et al (good reference material)
http://www.driveaccord.net/forums/showthread.php?t=5095
http://www.driveaccord.net/forums/showthread.php?t=39270
I installed Hawk Performance Ceramics 2 weeks ago and it has been the best upgrade I have ever done. There is no more shudder in the wheel under hard braking, and the car stops so incredibly hard I feel like my teeth will go through the windshield.
This upgrade solved all of my braking problems.... Highly recommend!!!!
Thanks aeoporta for all the help.
Andrew
Nice job aeoporta:thumbsup:
I stickied thread..:yes:
I1:wave:
Reactions: slimm1469
Thanks for putting this info together, I really appreciate it and I am sure many others will also!!
any tsb for strange somewhat hard shifting at low speeds? I just got the car, but when I'm looking for a spot in the parking garage it seems to clunk those gear changes (unless thats the TC locking up? my old civic had the same issues) The car is also fully warmed up at this point.
so 1st and 2nd is hard to shift, i know my civic shifts hard when cold but not when hot. You could try changing your tranny fluid, could also try a synthetic or semi synthetic blend. I am only aware of the 3rd gear pop out tsb. also check on clutch fluid level just to be safe. I have read that hondas get a tad harder to shift if your tran fluid isn't changed out at about 10 to 15k apart from that I haven't seen anything so far. sorry not very helpful i know
its sort of the same surge that you get when its cold with light to medium throttle, but I get this when the car is fully warmed up and you're applying very light throttle. Best way to picture is looking for a spot in a garage going from 5-20 and back down, or in stop and go...its sort of like the car shifts 1-2 then the 2-3 either clunks or the TC is locking up or something. I'm just trying to gauge if this is a normal thing or not. I have about 13-14k on the car right now.
This site has made me aware of a frighteningly large amount of TSBs..which I am both thankful and sort of sad about. One thing that still sort of bothers me is the eco/vcm system. I actually don't mind the operation of it..but I hate that the light will flash on and off when commuting to work in traffic, somewhat distracting really.
there's quite a few people who lament the passing of the 6MT sedan..heh well I've actually noticed this before too..I thought I was just shifting to D too fast (after reversing). I need to check my VIN to see if this applies.
Do you know if the dealers will remove the extra glass in front of the Nav that was changed for 09+?
awesome job but i recommend you bolding certain words in the post and also separate them in different sections like, interior, exterior, engine, suspension, aftermarket, custom, DIY, TSB, etc.
that would make it easier to find something i think, thats just a suggestion
not bad looks better but i would delete some spaces and make each category more bunched up, but its getting there
Dope thread. Makes sense. Something that most threads lack... Good job mang.
1 - 20 of 90 Posts
